Update.
So i got under the car. And this is what i saw.
- Offside Front Sub-frame attachment rubber mounting deteriorated resulting in excessive movement (2.4.G.2)
The tear drop is bolted to the car and not the sub frame. The main bolt then goes through a massive washer and through the sub frame 2 small washers then held on with a nut. I'm guessing the washer has broken away from the tear drop.
Regarding the other side
- Nearside Front Sub-frame attachment bracket/mounting insecure (2.4.G.1)
Again i'm guessing the washer has broken away from the tear drop.
So
I've had a look for replacement parts but am a bit confused as to what part i need.
I've had a look on mini spares but got confused about whether I need a
6 2A4292 Packing washers, front panel to subframe - 1976 on A/R for the offside to fill the gap between tear drop and sub frame.
cheers for any help again.
Edited by JCmini, 10 May 2018 - 05:04 PM.
