I'm stripping my mayfair to a bare shell and at the moment I'm trying to get the rear subframe off. A couple have snapped when doing so but no biggy.
I have one bolt left, nearside front mounting point of the rear subframe, the top bolt. It just spins and doesn't want to come out. Tightening it doesn't do anything either.
Am I right in thinking this is probably because the captive nut on the other side has come loose?
Is my best bet to just cut through the sill to get at it? The whole area will be replaced when I restore the bodywork. Cheers.
Rear Subframe Bolts
Big Sam
, May 09 2018 05:07 PM
2 replies to this topic
Posted 09 May 2018 - 05:07 PM
Posted 09 May 2018 - 06:24 PM
Yup
Your captive nut has given up
If your replacing the sills then just cut a hole for easy access or you can put a hole on the reinforcer plate in the companion bin this will also allow access to the captive nut
Good luck
Mark
Good luck
Mark
Posted 10 May 2018 - 07:47 PM
Cheers, that'll be this weekends job then!
