Rear Wheel Bearing Seized
Posted 10 May 2018 - 03:59 PM
Posted 10 May 2018 - 04:27 PM
http://www.minispare...=600/2A7351.jpg
An exchange radius arm might be the best option, let someone els do the recon work... 😁
Ben
Edited by MacGyver, 10 May 2018 - 04:28 PM.
Posted 10 May 2018 - 04:42 PM
What make wheel bearing was it? I fitted a minispares one and within 500 miles it done similar to yours and scrapped a tyre, hub and freshly reconditioned radius arm
Yep radius arms sounds like it's scrap if you could just pull the axle out. Probably need a new hub as well.
Posted 10 May 2018 - 06:02 PM
Posted 10 May 2018 - 06:07 PM
Edited by Aaron3, 10 May 2018 - 06:07 PM.
Posted 10 May 2018 - 06:32 PM
Mine was a minispares too and its only done 250 ish miles and yes the hub is scored to death behind the inner race, Im absolutely gutted is the car is all freshly rebuilt. I figured the arm would be mince meat. My shopping list is growing lol
Send them an email with photos, I got money back from them. When did you buy them? I think they need to look into there supplier a bit more.
I would only buy Timken's (or another big brand that I can't remember) now, I would change the other side as well. Timken's may cost 3 times as expensive as the non genuine types but saves a lot of money and hassle in the long run
Posted 10 May 2018 - 06:46 PM
Wow that sucks... I'm starting to seriously paranoid about where I buy my parts from now...
Hopefully they'll offer a refund as that's simply pathetic
Posted 10 May 2018 - 07:19 PM
I normally would buy timkin, but to be honest I had trouble with them too when I did the front bearings, the tolerances where way off I I couldnt get rid of the play no matter what method I tried, they where swapped for another set of timpkin but took some arguing and the second set went on fine.Send them an email with photos, I got money back from them. When did you buy them? I think they need to look into there supplier a bit more.
I think Ill make some wooden bearings lol
Posted 10 May 2018 - 07:37 PM
Bummer, but with a new Bearing, you'd expect better.
As the others have said, the Arm is scrap.
A similar thing happened to me a long while ago, but about 200 miles from anywhere (literally).
