Engine Fan?
Sanjay38
, May 11 2018 12:49 PM
6 replies to this topic
Posted 11 May 2018 - 12:49 PM
Does anyone know why the fan is constantly on on my car??as soon as I start the engine it kicks in,I have a cooper 1275 mpi 1997any advice would be much appreciated
Posted 11 May 2018 - 01:16 PM
It sounds like a defective thermal switch.
If it is you have two options:
1. Replace the switch with a direct replacement.
2. Wire the fan in to be manually controlled so that you can switch it on and off to suit conditions.
Posted 11 May 2018 - 01:38 PM
As cooperman says probably need to do the Rover modification by fitting the part in the link below.
http://www.minispare...06.aspx|Back to
Posted 11 May 2018 - 02:45 PM
Thanks very much for the advice guys much appreciated
Posted 11 May 2018 - 02:50 PM
That's a nice low-cost fix then.
Posted 11 May 2018 - 03:46 PM
Have you measured the resistance across the sensor switch terminals?
Posted 11 May 2018 - 04:53 PM
Its almost always the temp sensor or the wiring to it. Unplug it clean it up and refit. Its common on most mems rovers. Its a fail safe to stop you overheating when its getting dodgy signal from the sender
