Running To Cold.
Posted 12 May 2018 - 12:26 AM
When I had it, it was running normal temps. Since he has fitted it, it runs cold, I mean cold, 57c on a digital thermometer titled inside the top hose.
82c on the head itself and 70c on the top hose after shut down.
He has, of course, blanked his water pump bypass, and fitted a thermostat (88c) with holes drilled to allow water to flow.
What could be causing this? He has no heater tap, just an open circuit.
Help please.
Posted 12 May 2018 - 12:39 AM
drilled too many holes. you only need the one small one that should already be there. it is just not getting up to temp.
Posted 12 May 2018 - 12:43 AM
Posted 12 May 2018 - 12:47 AM
how do you mean did not help?
that tells me nothing.
Posted 12 May 2018 - 12:50 AM
Posted 12 May 2018 - 08:01 AM
Posted 12 May 2018 - 09:01 AM
Where is the coolant going from the heater takeoff?
Posted 12 May 2018 - 09:22 AM
Through his heater......he doesn’t have a heater tap is all. It just flows all the timeWhere is the coolant going from the heater takeoff?
Posted 12 May 2018 - 09:27 AM
You shouldn't need any additional bypass if the heater is connected 100% of the time. Does the heater blow nice and hot? The heater matrix will be acting as an auxiliary radiator and possibly overcooling?
Posted 12 May 2018 - 10:00 AM
He now has a standard, undrilled stat, still sunning cool. His last head had the bypass & the same heater hose setup, ran normal temps.You shouldn't need any additional bypass if the heater is connected 100% of the time. Does the heater blow nice and hot? The heater matrix will be acting as an auxiliary radiator and possibly overcooling?
Only thing that has changed is the head, which was on my engine and ran normal temps.
Confused much??
Posted 12 May 2018 - 10:21 AM
The standard bypass gets the hot coolant from the top of the engine and sucks it straight back into the block and bypasses the radiator, which means it'll heat up quicker. It also means the coolant is flowing past the thermostat
Having the heater tap side on 100% and a full thermostat means the coolant flow will all be going out the other side of the head and not flowing on the thermostat side of the engine?
Posted 15 May 2018 - 12:15 AM
A heater will drop the temp by probably over 5 degrees
I have run an oil cooler stat in heater hoses so it only comes in when needed.
