Another Problem Starting Thread.
Posted 12 May 2018 - 07:52 PM
Posted 12 May 2018 - 08:02 PM
It can get snagged on sharp corners...
Does seem more like the starter tho.
Ben
Posted 12 May 2018 - 08:33 PM
Posted 13 May 2018 - 06:51 AM
Have you checked the condition of the positive lead from battery to starter?
I'll follow it though and check, thanks.
Ben
Something else to consider is the engine management relay under the bonnet, one of the relays in there is for the starter motor. I had a problem with mine which gave an intermittent problem starting, although when it was playing me up I got only ignition lights and nothing at al, from the starter or solenoid.
I'll have a look to see if there's something obvious. Im thinking that since I've got something from the starter then it's less likely.
Posted 13 May 2018 - 12:38 PM
Also when you are not using the car, do you disconnect the battery? If so are are resetting the immobiliser using the key fob?
