Do these look ok? I had a bit of a job removing the nylon cup. Had to resort to heating them to the point of melting and then scraping the remains out. I assume that hole at the bottom is meant to be there?
Also, how can you tell if the bush inside the tubular part is still ok? I don't want to replace it if its fine
