Rear Brakes
4 replies to this topic
#1 bluemini1979
bluemini1979
  • 597 posts
  • Local Club: Colchester Mini Club
Posted 13 May 2018 - 07:16 PM
Have had my mini motd recently. It passed but the rear brakes were only just up to standard. The pedal was hard but after pushing hard to do the brake test appears to come to pressure lower down. Pedal doesnt pump up and I cant get any air out the system.
Anyone have any ideas where to start?
Car is a 79 with yellow tag master cylinder with the valve on the bulkhead, minispares 4 pot alloy calipers for 7.5 discs and 9/16 bore rear cylinders as recommended by minispares.
#2 smurfomatic
smurfomatic
  • 281 posts
Posted 13 May 2018 - 07:53 PM
One thing to check is the rear brake cylinders. I recently changed all the shoes on mine, pumping the pedal after adjusting each one, but the pedal was getting lower. Got to the last of the brakes and found the cylinder was leaking...
#3 Moke Spider
Moke Spider
  • 7,140 posts
Posted 13 May 2018 - 08:44 PM
I feel that the 9/16" Cylinders are too small, I think 5/8" would be the right size and would give more braking on the rears, however you just need to check they don't over-brake and lock.
#4 carbon
carbon
  • 2,414 posts
Posted 13 May 2018 - 08:45 PM
A 'just passed' for rear brakes would be my perfect MOT result - less chance of them locking up in the wet under heavy braking.
#5 timmy850
timmy850
  • 1,614 posts
  • Local Club: MITG
Posted 14 May 2018 - 06:58 AM
The drums are quite sensitive to proper adjustment, if they are a bit loose they will give a low pedal. Have you got the shoes on the right way?
Mini Spares
