Starter Clicks First Few Turns Of The Key, Then Will Start On 3Rd Or 4Th. Ideas?
Posted 15 May 2018 - 09:54 PM
Im assuming I need a new starter motor?
If thats the case, would a high torque one be a better option?
Cheers for the help.
Posted 15 May 2018 - 10:31 PM
Might sound obvious, but what condition is your battery in?
Posted 16 May 2018 - 12:34 AM
Battery terminals clean? Good earths all round? Battery condition and state of charge OK? There is lots of things to check before checking/replacing starter.
Posted 16 May 2018 - 12:47 AM
Sounds like it could be the solenoid giving up the ghost, if yours is a pre engaged starter its built into the starter, If it's an inertia style starter it's a separate replaceable part
Posted 16 May 2018 - 06:39 AM
Id say the solenoid as well, a duff or dying battery would give you a slow turn over, it would only tick if its on its last legs and not giving the starting power it needs. Check the wiring to the starter/solenoid to make sure they are tight and clean
Posted 16 May 2018 - 07:31 AM
Posted 16 May 2018 - 07:34 AM
It does sound like the solenoid playing games. No need for a "high torque" starter motor. I have the standard Lucas M35 starter on my high compression 1293 engine and it works just fine...
Posted 16 May 2018 - 11:59 AM
Posted 16 May 2018 - 12:11 PM
Was a new battery back in December, and ive had it on trickle charger a couple of time in last few weeks just to keep it topped up when not using the car. OK i'll look at the earths and go from there. Its going to a garage at the weekend so i'll mention that to them and see what they have to say.
thanks for all the help :)
Mini Technical Sections →
Problems, Questions and Technical →
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
electrical
Timing Light Not Working - No SignalStarted by adman020 , 13 Feb 2024 electrical |
