Mpi Won't Start, No Electrics.. Nothing! Need Help!
4 replies to this topic
#1 rubdub
rubdub
  • 70 posts
Posted 16 May 2018 - 05:03 PM
Hey guys,
Have a 98 MPI, over the past month or two (on occasion) it's been struggling to turn over but always did in the end.
Today after driving it for a half hour.. leaving it for another half hour it won't do anything.. No immobiliser light, or radio in accessory and won't start.
I had a feeling the rough start might have been down to a bad earth.
Any ideas or thoughts greatly appreciated!
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 16 May 2018 - 06:32 PM
dead battery
no earth straps to the engine
main power cable been severed
battery leads come
major engine fuse blown
electric fault due to corrosion
1000 and 1 things best start looking
sized no oil in it
Edited by ukcooper, 16 May 2018 - 06:33 PM.
#3 rubdub
rubdub
  • 70 posts
Posted 17 May 2018 - 11:07 AM
Thanks!
Had a quick fettle this morning.. seems the negative battery cable has a bad earth. Had the electrics back, car will now turn over but not start.
#4 Wiggy
Wiggy
  • 1,036 posts
Posted 17 May 2018 - 11:31 AM
Is the fuel pump priming?
Do you have a spark?
I'd also check/clean the ECU earth. It's on the left of the engine bay. Just to the left of the brake servo.
#5 rubdub
rubdub
  • 70 posts
Posted 21 May 2018 - 07:24 AM
Thanks!
Called out AA breakdown in the end. He said it started as a bad earth, and then a flooded engine.
Cleaned it out and back running now.
Thanks for advice guys!
