The barrel kept coming out of the rear door when opening so I've bought a new barrel set. Now the whole handle comes out when opening (at least the barrel stays in place). The pin was missing from the handle so I've used part of a rivet to hold it in place but the end of the barrel with the groove is smaller on the new barrel. My question is: Is the handle likely to be worn or do I have the wrong barrel? I'd like to use the new barrel as it is less worn and had more tumbler/leaves.
Mini Van Door Lock
StubyDoo
, May 19 2018 01:56 PM
No replies to this topic
