I seem to having an issue with the headlights on my 1972 Mini 1000
it originally started with the Drivers side headlight not working..
The bulb is ok, and I checked out the bullet connections under the grille and found a few of the double female connectors to be corroded.
I have since replaced them but I am having the same problem, I changed the loom to a newby and still no Joy.
the parkers don't work either, however if I switch to High beam both high beams work
So what I have is no parkers both sides, headlight only passenger side.
I have buzzed out the connections, including the earths with a Meter and everything seems to be ok.
I am now totally lost and have given up. has anyone got any tips re this issue , and or know of a Mini friendly electrical centres in the west London area..
Thanks in advance
Kevin
