Is there any reason the 7.5 disc wont fit with the correct flange, as the std hub I think is the same regardless of disc diameter?
If someone who has a set of alloy hubs and 7.5 discs could try them together, that would be perfect.
I look forward to hearing from you guys who have used the alloy hubs.
Also on a side note what rear caliper could I use to run 7-7.5" front discs on the back with a mechanical handbrake?
Edited by Jon937, 19 May 2018 - 09:09 PM.
