Fitting Spotlamps
Posted 19 May 2018 - 09:25 PM
I have bought a set of these spotlamps, just want to know Whats the best way to mount them with the centre bracket, they didnt come with any sort of mounting kit. Any help will be a appreciated.
Cheers!
Posted 19 May 2018 - 09:27 PM
Posted 19 May 2018 - 10:17 PM
Posted 20 May 2018 - 06:20 AM
This might help.
What I did with mine was drill through the lip that the bumper is attached to and and just attach them like that.
Another way of doing it which is probably better would be to attach them to the bumper, depending on how willing you are to drill through it.
3 bits of right angle steel or alluminum attached to the bumper (one left, middle on right side of the bumper), with holes drilled on the top to attach the metal bar to. This can then hold your spotlights by drilling through the metal bar where ever you want to attach the spotlight.
These attach to the bumper https://rover.ebay.c...tm/123084943711
This sits on top of the bracket for the spotlights to be attached to https://rover.ebay.c...tm/281318648379
Doing it this way will mean that you don't need to drill through the actual body of the car. All props given to Cooperman for that one!
http://www.theminifo...light-brackets/
Edited by WillCarter, 20 May 2018 - 06:23 AM.
Posted 20 May 2018 - 06:30 AM
Posted 20 May 2018 - 10:07 AM
Posted 20 May 2018 - 10:13 AM
The lamps on the car above are fitted to a works type bar which is available with all bracketry shown, heres a photo of mine
How did you fit these to the car, cheers
Posted 20 May 2018 - 10:14 AM
And I never actually answered your question, the brackets I linked will attach to the valance, the lip that bumper is attached to. The prongs go through the grille but I'm not actually too sure what they should attach to.. then of course the top hole is to attach the spotlight to
Cheers for the help will, appreciate it!
Posted 20 May 2018 - 02:50 PM
They bolt to front panel corners and middle bracket under bumper
Posted 20 May 2018 - 04:20 PM
