Megajolt
Posted 20 May 2018 - 03:22 PM
Posted 20 May 2018 - 08:05 PM
Im not sure that’s the cause of your smoke.
How do your plugs look?
Posted 20 May 2018 - 10:07 PM
Mine does it too, well I don't know if it sucks back at manifold vaccuum; I just drain it off at MJ end but be warned, if the pipe goes hard in the cold you'll damage the internals if using any amount of force to pull it off and have to re-solder some connections inside
I've asked a similar question in the past on here
Posted 20 May 2018 - 10:13 PM
If you're running a bit of a Cam, pretty much anything over a stock profile, it can do this as there will be some pulsed positive pressure in the manifold at times.
You can fit a trap, plumbed to the Manifold with bigger dia hose (about 1/2" should do it) then run from the trap with a smaller dia hose (1/8"). Run this small hose up to a high point, well above the carb before dropping down to the Megajolt connection.
The Trap doesn't need to be anything fancy, I made one from a steel canister type fuel filter, it's about 1-1/2" in da and a similar length.
Posted 21 May 2018 - 12:39 PM
