Quick Question - Rear Hub Nut Washers....
1 reply to this topic
#1 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 21 May 2018 - 07:56 AM
Discovered that one of my rear bearings was so tight as to be impossible to turn by hand, so ordered a Timken bearing set and set about sorting it out last night.  All went to plan, was much easier that I expected, but when putting it back together I discovered the hub nut washer is no longer flat.  Ordered a new one, no big deal.
Anyway, I've had a proper look at the washer today, it is concave by about 0.5mm at the edges, but it also has a groove on either face about 5mm in from the edge of the hole, whereas the replacements look completely flat.  I can't tell if the grooves are supposed to be there or whether they've been worn in.  It looks like the hub was massively over-tightened to remove play from the bearings, which has bent the washer.
Does that sounds like what's happened here?
Everytime I look at a new area on this car I find some dodgy bodge or other!
#2 Spider
  • 13,929 posts
Posted 21 May 2018 - 08:58 AM
Be good to see a photo, but it sounds like either it's a bodge washer or possibly worn, but they are hard.
They are dead flat and (as mentioned) hard. The centre hole will be chamfered on one side only - the chamfer goes towards the Bearing
