Hp At The Wheels
Posted 21 May 2018 - 01:09 PM
Posted 21 May 2018 - 01:22 PM
Edited by cal844, 21 May 2018 - 01:23 PM.
Posted 21 May 2018 - 01:28 PM
Posted 21 May 2018 - 02:41 PM
An 11% increase by just fitting wider wheels? A mini on 10x3.5 would gain power then lmao.
Quite possibly due to rolling resistance and inertia
Posted 21 May 2018 - 03:02 PM
Posted 21 May 2018 - 03:50 PM
At the wheels is very subjective. It depends on the grip of the rollers and the grip of the tyres. It also depends on the climatic condition at the time of the run. Rolling roads are great for setting up the engine across the entire rev range in a controlled environment but you can't compare like for like unless it's on the same rollers with the same amount of downforce on the tyres on the same day with the same atmospheric conditions. I know what mine gives at the wheels but I have no idea what it gives at the flywheel. You can only guess because new CV joints, new pot joints, new wheel bearing and a rebuilt gearbox all have an impact on the wheel horsepower.
Posted 21 May 2018 - 04:05 PM
It would be unlikely that the 'at the wheels bhp' would be much diffferent with 10" or 13" tyres, although as stated above it will be slightly reduced.
What is true though, is that the maximum speed and the acceleration in the higher speed range will be reduced on a car with 13" wheels/tyres due to the much increased drag.bThe fuel consumption will also be higher.
If the frontal area of the huge wing mirrors, the very wide wheel arch extensions and the tyre width is calculated it is clear that the additional drag will make quite a difference when compared to a car with no arch extensions, 3.5" or 4.5" wheels with 145 tyres and no wing mirrors (legal on Mk.1 & Mk.2 cars and on some Mk.3's). One can only wonder how many bhp is used up by these parts on a late car at, say, 75 mph.
Posted 21 May 2018 - 06:10 PM
You have a very special dyno, for it to measure inertia.
13" wheels, stock engine I had 22% loss
On the 1330 clubman ( 13" avon slicks, sccr box) we had 15% loss.
Posted 21 May 2018 - 06:14 PM
Posted 22 May 2018 - 10:53 AM
has anyone with 13 x 7" got figures on fly and wheels
140 @ the fly
118 @ the wheels
Posted 22 May 2018 - 11:34 AM
140 @ the flyhas anyone with 13 x 7" got figures on fly and wheels
118 @ the wheels
16% loss, that's not bad!
Posted 22 May 2018 - 11:51 AM
Posted 22 May 2018 - 12:07 PM
Dont waste your time compairing some numbers.
maybe you loose some acceleration but you gain more grip in corners or better braking performance.
Posted 24 May 2018 - 10:46 PM
or less in the wet or snow
Posted 25 May 2018 - 07:39 AM
On the dyno i use its measured at the wheels. Make no difference as to what tyre you run as its dyno packs so no tyre is in contact with the ground it bolts to the front hubs. True power figures at the wheels.
