Hi
We fitted the mini spares gear selector leak kit however its still loosing oil more rapidly then I would like and the only sign of a leak is around the gear selector. Can I mess the install up or could I be missing something?
John
Gear Selector Leak Kit - Fail
Minimoo84
, May 22 2018 07:47 PM
5 replies to this topic
Posted 22 May 2018 - 07:47 PM
Posted 22 May 2018 - 07:58 PM
If the bore that the seal fits in to has a scratch in it (usually from digging an old seal out), it will still leak for sure.
Posted 23 May 2018 - 03:03 PM
Thank you, so would it be worth pulling the current one out and inspecting it?
Posted 23 May 2018 - 04:19 PM
You might enough room to put a second seal in. You can do that without dropping the oil.
Posted 23 May 2018 - 04:42 PM
I've got 2 seals in mine, before and after the rebuild and know a lot of others do the same. Definitely worth it!
Posted 23 May 2018 - 08:03 PM
Will try the 2 seal method! Thank you
