Spi Learning!
4 replies to this topic
#1 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 22 May 2018 - 08:16 PM
Hey guys!
Ive recently picked up another mini, and, although Ive had mini for many years now, this is going to be a massive learning curve due to it be an spi!
So my first question is regarding alarms and immobilisers...
Ive done lots of searching but Im still unsure on what I might have.
Its a 1994 sprite spi. It starts and runs. I only have keys, no fobs or anything. But behind the dash trim is a small black box which I believe is to do with the alarm and/or immobiliser..?
Theres no dash, just standard 2 clock binnacle, so no idea where the red led should be if it should have an alarm...
Any ideas?
Thanks!
#2 FlyingScot
FlyingScot
  • 2,660 posts
Posted 22 May 2018 - 08:29 PM
Okay the alarm system can be either 3AS ( 1 button fob) which is relatively easy to bypass or 5AS (2 button fob) which is not.
Red led is in the 2 clock binnacle if present. Sounds like you don’t have an alarm/immobiliser and the black box is a dummy unit which were fitted to some cars.
Can you quote the part number off the “alarm box”?
FS
#3 screech
screech
  • 3,136 posts
Posted 22 May 2018 - 08:49 PM
On the binnacle, on the bottom left corner is a blanking cap, I guess where the led should, or would be if installed.
The black box has plenty of wires going to it, why would it be a dummy, very strange!
The sticker on it reads..
YWZ100060
3LB
52010141A
0695
Lucus
#4 Pops_Guild
Pops_Guild
  • 363 posts
Posted 23 May 2018 - 12:22 AM
Hi there, is your 94 Sprite a JDM? look anything like the photo I've attached or the link to part at Somerford Mini?
If so it's the cat buzzer that is required for Japan and not an alarm in the strictest sense.
http://www.somerford...roducts_id=5742
Attached File  buzzer.jpg   80.38K   1 downloads
#5 humph
humph
    How bad can it Be?
  • 1,065 posts
Posted 23 May 2018 - 07:56 AM
It's a dummy unit as far as I can tell, part number links to
https://rimmerbros.c...em--i-YWZ100060
