Testing A Map Sensor (Again)
57 replies to this topic
#46 pete l
pete l
  • 1,358 posts
Posted 12 June 2018 - 12:14 PM
OK, so I have different coloured wires, I have Yellow, red and purple.
Attached File  map1.jpg   33.93K   0 downloads
Attached File  map2.jpg   33.59K   0 downloads
Another thing that I have never seen that shows up in the photos is someone has scribed letters on the plug. Someone has been in there, why else would there be writing on the plug.
I have measured this, the purple one is ground, the yellow is 5 volts which means the red one is signal back to the ECU.
#47 Wiggy
Wiggy
  • 1,036 posts
Posted 12 June 2018 - 12:24 PM
I think that:
Purple should be 5V
Red should be Signal
Yellow should be Ground.
So it looks like someone has got mixed up!
#48 pete l
pete l
  • 1,358 posts
Posted 12 June 2018 - 12:28 PM
MY WIRING IS WRONG.
I've just tested a MAP sensor with the power on "the wrong way" and it works. It works, IT F****** WORKS. I am over the moon.
Thank you everyone on here, thank god for this forum. I love you all.
xxxxxxxxxxxxx
#49 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 12 June 2018 - 12:55 PM
Wooo, that was tense. I've been watching this thread thinking "why on earth did I buy an MPI?!"
Glad it's sorted. You've got plenty of spare sensors now!!
#50 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 12 June 2018 - 12:57 PM
Well, in that situation there was never a good chance of a one getting to the real problem applying advice based on an un altered system. What you have there is an altered system which is wrong. I had suspicions early on and why I hinted at you to look at actual wire to terminal configurations.
Glad you got there in the end
Edited by Sprocket, 12 June 2018 - 12:58 PM.
#51 pete l
pete l
  • 1,358 posts
Posted 12 June 2018 - 01:06 PM
I now need to rip appart the wiring loom to see what's been done to it.
Is this a common faillure this part of the loom ? I know about the coolant temp sensor, and I've heard about the TPS wiring chafting, but never heard of the MAP causing problems.
#52 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 12 June 2018 - 03:35 PM
What year is your mpi Pete? I had one in over the weekend and it had a black map plug
#53 pete l
pete l
  • 1,358 posts
Posted 12 June 2018 - 04:59 PM
It was first registered in July 1997. It did come with a brown map. I don't know the difference between the two.
#54 cian
cian
  • 869 posts
Posted 12 June 2018 - 05:10 PM
I wonder was there a wiring change through the mpi production? I believe the one I had in was an early mpi it had a black map plug, my car is a 99 with a white plug
#55 pete l
pete l
  • 1,358 posts
Posted 12 June 2018 - 05:12 PM
There was an ecu change. So maybe there was a wiring change
#56 pete l
pete l
  • 1,358 posts
Posted 13 June 2018 - 07:51 AM
Here's what I have just found. Is this a Rover bodge or has someone managed to find a new plug and solder it in ?
Attached File  IMG_20180508_150858.jpg   69.58K   0 downloads
#57 cian
cian
  • 869 posts
Posted 13 June 2018 - 08:49 AM
Looks like someone has been there before doesn’t appear factory! So the loom wasn’t good after all
#58 pete l
pete l
  • 1,358 posts
Posted 13 June 2018 - 12:39 PM
The loom itself was fine, in that there were no shorts, good connections to the ECU etc.
The problem was that I didn't know which pin the 5 volts should have been going to. I never ever ever thought of crossed wires on what looked like an original engine harness.
I found that the 5 volts was on the puple wire and used that reference to test my MAP sensors, I was convinced they were all dud, even the one you sent me. I never thought I was doing anything wrong because I was getting a voltage reading out of the signal wire.
Usually, an electronic device either doesn't work or blows up if you power it up the wrong way round.
These MAP sensors are strange :-)
Pete.
