Fuel Mixing In Oil!
Posted 23 May 2018 - 12:49 PM
Iam getting fuel mixing in oil.
Ive done all the trail an errors just checking with people whos maybe had this problem.
Engine was rebuild last year its 1275 bored out 1293 now.
I have changed my mechanical fuel pump with new one from minispares wasnt the problem.
I rebuild my carb hif44 and cleaned it in ultrasonic cleaner still not the problem.
I have tried my mates hif44 still mixing.
Ive played about with mixture screw made it run lean but still mixing.
Starting to think its my piston rings but wanted to ask before ripping it apart
Thanks trev
Posted 23 May 2018 - 12:52 PM
only two places (or three) fuel pump. change for an electric to eliminate that. carb not really unless the engine build is that poor....
compression test?
leakdown test?
Posted 23 May 2018 - 12:57 PM
Was new fuel pump fitted but i guess the electric one would be better off.
My compression is 120psi across all four. Starts and runs lovely.
Havent done a leak down test yet as need to grab one.
Posted 23 May 2018 - 01:15 PM
On my engines I renew the two gaskets(either side of the spacer block) and use a smear of sealant with them too, I've yet to have an issue in 8 years doing it this way, I also use sealant on water pump and basically any gasket
Posted 23 May 2018 - 02:32 PM
Did you change the gaskets when you renewed the pump?
Hi cal 84
How would the gaskets let fuel in oil? sorry if silly question.
I didnt have any gaskets for my old or new one. My engine builder said it was ok to use cardboard like cereal box.
ive noticed i have one bolt longer than the other so was only able to fit homemade gasket to engine side.
Edited by AUSTINMINI1985, 23 May 2018 - 02:34 PM.
Posted 23 May 2018 - 02:51 PM
Ho,
The gasmet or lack of will only cause the oil to leak out all over the floor, certainly won't cause the fuel to get into the oil.
Posted 23 May 2018 - 02:53 PM
Hi cal 84
The fuel leak is usually the internal pump diaphragm (between top and bottom of pump) fuel then leaks into the sump down the cam lever.
Posted 23 May 2018 - 02:59 PM
Cal844 thanks. Thats why i changed pump to brand new one. was hoping it was the problem.
I was driving car all winter and iam not sure when this started happening. So only thing i can think off would be my piston rings.
Posted 23 May 2018 - 03:41 PM
Hey bat thanks for that.
How sure are you is running properly? Could it be borewash from rich running?
Posted 23 May 2018 - 03:57 PM
HiHow sure are you is running properly? Could it be borewash from rich running?Hey bat thanks for that.
The engine starts and ticks over lovely.
Ive had it driving when i change oil for trail an errors.
When i try to put my foot down it struggles abit so have to release petal then would drive again. Wasnt best going up hills.
Sparks were pure black. Yes was running rich
Edited by AUSTINMINI1985, 23 May 2018 - 03:59 PM.
Posted 23 May 2018 - 04:47 PM
Posted 23 May 2018 - 04:54 PM
ya haven't put old oil mixed with petrol in it b y mistake, wouldn't be the first person to that ????
No no definitely not its cost me 5 tins so far outa halfords
Posted 23 May 2018 - 05:08 PM
I think thats your issue here perhaps if you post your engine spec someone can recommend a needle to suit.
Posted 23 May 2018 - 05:33 PM
[quote name="AUSTINMINI1985" post="3540157" timestamp="1527091068"][quote name="dyshipfakta" post="3540155" timestamp="1527090093"][quote name="AUSTINMINI1985" post="3540147" timestamp="1527087550"]
I was driving car all winter and iam not sure when this started happening. So only thing i can think off would be my piston rings.[/quote]How sure are you is running properly? Could it be borewash from rich running?[/quote]Hi
rich[/quote]
Just to confirm. So it could be bores damaged instead off rings.
The engine is a+ engine 1275 bored out to 1293
Runs hif44 carb.
What would a new needle do? My needle is bdl
Edited by AUSTINMINI1985, 23 May 2018 - 05:49 PM.
Posted 23 May 2018 - 06:04 PM
