Valuation On My Micra Powered Mini
2 replies to this topic
#1 smudger068
smudger068
  • 344 posts
Posted 26 May 2018 - 12:26 PM
Hi All,
Im hoping to gauge a valuation on my Mini. Im looking in the near future to sell as the car has been on axle stands in my garage since Snetterton.
Spec is:
Micra Allspeed conversion Frame New from Allspeed.
1.3 Micra engine (On the log book)
Fusion Fabrication Manifold
4 branch Tubular
Largw core rad.
Pipercross Airfilter
Mini Centre Speedo (Which I need to get a cable made for as I have never had it working)
Smiths oil and Temperature Gauges ( Both are plumbed and work fine)
5 speed gearbox, tops out around 105-110mph.
Completely removable front
Minisport 4 pot calipers and discs
Mini ultralite wheels with Yoko 048r tyres.
Minisport Hilo on the front
Gaz Coilovers on the rear.
Maniflow centre exhaust.
Roll Cage/Bucket seats
Bosch High pressure fuel pump
Fibreglass Mk1 bootlid
Minispares rosejointed adjustable camber arms
Adjustable castor arms.
Adjustable rear camber/castor brackets
Braided brake lines all round.
No Rot! There is metal where metal should be. It is deseamed to an extremely high standard.
It has been on the road and hasnt seen a wet day in the 9 years I have owned it.
Comes with spares:
STORMFORCE Car Cover built for the Mini
4 pot brakes with damage to one half of one so a complete spare caliper.
Original bootlid.
Springs
Loads of other bits.
Build thread and life of me owning the car. It looks as is from Snetterton.
Could do with a new loom it works and will always work but it is not perfect.
Front end body work will be professionally done for the new owner. Its just wear from constant on and off.
http://www.theminifo...ini-cg13-build/
It does qualify for MOT exemption and Tax exemption in January. It will come with an MOT for the next buyer.
Would £3500- £4000 be fair?
Reason I am looking to sell is because I am looking to buy an R8.
Edited by smudger068, 26 May 2018 - 12:47 PM.
#2 Carlos W
Carlos W
  • 10,110 posts
Posted 26 May 2018 - 06:51 PM
If you put it up at that it’ll certainly be priced to sell.
Just under the 4K mark maybe?
You can come down but you can’t go up
#3 smudger068
smudger068
  • 344 posts
Posted 26 May 2018 - 07:09 PM
Brillant Thank You.
