Rivnuts
Posted 28 May 2018 - 06:22 PM
download.jpeg 6.04K 1 downloads
Posted 28 May 2018 - 06:45 PM
If you e only got a few to fit they’re ok but it’s not a lifetime tool.
I have one of these now and the mandrels are a nicer design and have done more work than the three cheaper ones I had previously.
https://m.ebay.co.uk...wkAAOSwcfdbAQLl
Posted 28 May 2018 - 07:38 PM
top tip don't tight the rivnut all the way up leave a mm gap between nut and gun otherwise they get stuck
Posted 28 May 2018 - 08:12 PM
i have one that does up to 6mm in steel. i got it as i had a lot to do, but you do not need to have one to fit them and for larger than 6mm i use a bolt some nuts and some washers.
Posted 28 May 2018 - 09:37 PM
Posted 28 May 2018 - 09:41 PM
false thinking- stainless is generally weaker that mild steel. Stainless also corrodes mild steel that it is in contact with if damp. look up galvanic corrosion. we use stainless weld nuts and have steel bolts that are a service part so they dont fail.
Posted 29 May 2018 - 10:09 AM
I meant comparing stainless to aluminium
Posted 29 May 2018 - 10:12 AM
just use steel ones. stainless is just a pain. did I mention galling?
Posted 29 May 2018 - 03:57 PM
go on then, what's galling
Posted 29 May 2018 - 04:20 PM
It's annoying to hear a question like that. Lol.go on then, what's gallingjust use steel ones. stainless is just a pain. did I mention galling?I meant comparing stainless to aluminium
Edited by whistler, 29 May 2018 - 04:20 PM.
Posted 29 May 2018 - 04:30 PM
why?
Posted 29 May 2018 - 06:47 PM
It's a play on words. Galling means annoying. It was meant as a joke.why?It's annoying to hear a question like that. Lol.go on then, what's gallingjust use steel ones. stainless is just a pain. did I mention galling?I meant comparing stainless to aluminium
Posted 29 May 2018 - 07:06 PM
why?
Ahhh I see, thought it was some strange meaning for screws or something
Posted 29 May 2018 - 08:11 PM
