1992 SPI
4 inline glass fuse box on the bulk head
Top fuse, wires going in on the left side are white, and the right side a green wire, these are related too indicators. This fuse keeps blowing, then i get no indicators (hazard still work), horn or full beam.
indicator stork and switch replaced approx 1 year ago and had no problems.
i have checked all major grounds, wire and connections the best i can, even tried my old indicator arm to see if that was the problem. Also went through all other fuses and checked all relays connection. The indicator switch relay still works when the hazards are used.
any ideas
cheers
