Hi folks,
I bought 1995 Spi (N reg) about a year ago. I had it serviced and changed the parts that needed to be changed under the car such as driveshaft, front hubs, discs and track road ends etc. as much as i saw. Car has a little rust and bubbles so I decided the full restoration.
I was just wondering what parts check on the engine once it is out ? How do I know if I have an healthy engine ? Car has done just over 100k. It runs and sounds fine as I have been told but I have got no idea what has been done to the engine by the previous owner. I just want to get it repaired as it will be harder later on when we put it back. Also I found it a bit slow but I am assuming this is the usual case with minis. I have not done more than 400-500 miles in total with this car.
Any help with this would be highly appreciated.
Thank you in advance.
