Just got my mini ready for paint and boom goes the compressor
Can any one help it’s a 4 hp twin pole 240v single phase motor . I fitted a new capacitor and that lasted 1 minute then boom . Can any thing other than the motor cause this to blow abit reluctant to buy a new motor if something on the compressor would cause it to blow ?? Pump it free moving ! And when it blow yesterday there was no pressure in tank as it only ran for less than a minute .
Help please as mini is desperate for it’s top coat .
0B7E1455-0FED-4F38-8655-C7A1DBFC096D.jpeg 71.87K
2 downloads
Blown Compressor Capacitor Help Mini Waiting For Paint !
mm man
, Jun 03 2018 08:47 AM
4 replies to this topic
Posted 03 June 2018 - 08:47 AM
Posted 03 June 2018 - 07:17 PM
Looks like the centrifugal start contacts are not opening, causing the start cap to overheat.
Posted 04 June 2018 - 11:31 AM
Thanks for the reply and link my motor turns out to have a start and run capacitor so no switch.The shop that gave me the replacement capacitor gave me the wrong type just a start one rated 250v not a start and run type rated 450v . So there giving the correct one so fingers crossed that works if not it's a new motor .
Posted 17 June 2018 - 06:07 PM
It turned out to be the capacitor only :) fitted the correct 450 v start and run type and this happened
736DE26A-5873-4660-ACAA-2E5A2939C2DF.jpeg 60.34K
0 downloads
C0119266-130E-42C1-BC24-F65F7609B6D6.jpeg 57.41K
0 downloads
It got its coat on !!
(Poor photo quality tho )
Posted 20 June 2018 - 04:43 PM
I've had the start windings (iirc that's what they're called) go on mine before which eventually lead to the capacitor going.
Replaced it and it lasted a bit longer but eventually went again.
