Clutch Question Mini 1000 1988.
12 replies to this topic
#1 the sweeney
the sweeney
  • 111 posts
Posted 04 June 2018 - 05:26 PM
Ive loosened on the clutch housing (look like 13mm bolts) ( about 5 bolts around the diameter of the housing),  as I was going to take the clutch out, ive not touched anything else,
ive since learnt it had a clutch recently fitted so don't need to, my question is will it all still be lined up ????? thanks in advance
[attachment=195424:lowered mini.JPG]
Edited by the sweeney, 04 June 2018 - 05:35 PM.
#2 nicklouse
  • 19,066 posts
Posted 04 June 2018 - 05:34 PM
well the housing "wok" is held on by 8 bolts and they are either 7/16" AF or 1/2" AF headed 5/16 unc bolts is this what you mean? it is just a cover.
#3 the sweeney
the sweeney
  • 111 posts
Posted 04 June 2018 - 05:38 PM
oh sorry  I did explain well enough, yes ive got the cover off (wok) this is actually on the clutch itself that im talking about, thanks
Edited by the sweeney, 04 June 2018 - 05:39 PM.
#4 Swift_General
Swift_General
  • 871 posts
Posted 04 June 2018 - 05:39 PM
There should be no issue in just re tightening the the 'wok bolts if that's what you're referring to. No more than about 18 ft lb though as otherwise you risk stripping the threads in the alloy.
Edited by Swift_General, 04 June 2018 - 05:41 PM.
#5 the sweeney
the sweeney
  • 111 posts
Posted 04 June 2018 - 05:40 PM
im actually on about the clutch itself pal, thanks
#6 the sweeney
the sweeney
  • 111 posts
Posted 04 June 2018 - 05:44 PM
hang on guys ive taken a pic
#7 Rorf
Rorf
  • 866 posts
Posted 04 June 2018 - 05:48 PM
Clutch plate sits on a splined shaft so wont go out of alignment like a normal car.
If you are rebuilding a recently acquired project then I would not trust the previous owner/builder and strip the engine and gearbox to see what gremlins there are or not.
#8 the sweeney
the sweeney
  • 111 posts
im pointing to where I mean,if ive undone these then re tightened will it still be lined up ok??
#9 the sweeney
the sweeney
  • 111 posts
Posted 04 June 2018 - 05:51 PM
Cheers Rorf, I know what you mean, but I know the last 2 owners of the Mini, thanks for letting me know about it being on a splined shaft, Bonus !
#10 Swift_General
Swift_General
  • 871 posts
Posted 04 June 2018 - 06:01 PM
As long as all the bolts have been loosened equally, should be fine. I would personally use new spring washers for peace of mind, but that's just me.
#11 Thelowrider
Thelowrider
  • Just Joined
  • 90 posts
Posted 04 June 2018 - 08:21 PM
That particular setup is okay as the hub assembly is built into the pressure plate which sits on the taper of the end of be crank so you will be fine
#12 the sweeney
the sweeney
  • 111 posts
Posted 04 June 2018 - 08:27 PM
New lock washers ....check, thanks for your comments, helped me out a treat!
#13 Rorf
Rorf
  • 866 posts
Posted 05 June 2018 - 06:15 AM
Pic says a thousand words :lol:
