Clutch Master Cylinder
Posted 04 June 2018 - 09:21 PM
Posted 04 June 2018 - 09:38 PM
yes but remember the chamber needs to be full as the port is halfway down. and some times it needs a bit of help getting some fluid into the ports to get it working. gravity bleed. ie open up the slave bleed and go make a cuppa. make sure the bleed tube is in a container.
Posted 04 June 2018 - 10:30 PM
If its been out of action for sometime and a bit dry inside ports I have found by placing a piece of clear tubing (so you can see not to get a mouthful) over outlet of m/c and sucking on it to get things moving. Once this is done you may find a couple of pumps on the pedal will get things moving.
Posted 05 June 2018 - 09:06 AM
Thanks chaps. Had a dim moment last night, had to rush out and check that I'd actually put the pin in. I had, and it was pretty sweaty with clutch fluid- so I'll reseal the master anyway.
