Does anyone know what to use to replicate the original bitumen type floor covering. I had to chip some away to make repairs but do not really want to strip the whole lot out.
Original Floor Bitumen Sound Insulation
Posted 06 June 2018 - 07:17 AM
Posted 07 June 2018 - 05:13 PM
Just don't. Stuff is mega heavy and is a water trap.... I removed all mine and it hides everything. If you want to quieten down a Mini get Silentcoat, £80 to do the entire car and it'll be less weight and more effective than the bitumen stuff.
Posted 08 June 2018 - 10:31 AM
silentcoat is even worse to remove after 10jears and also a water trap...
A healty mini is loud to drive...
Posted 08 June 2018 - 11:02 AM
I used this stuff, eventually sets hard like the original..
https://www.ebay.co....pQAAOSwbsBXpEoe
I know I could have been neater
Also used it under the bonnet, that made quite a difference.
Posted 12 June 2018 - 08:39 PM
Panky, thanks for that mate good pics also. I think it will be just as good after it's been heated with a heat gun. Trick is to not let water in in the first place but that's not easy with a mini.
Posted 12 June 2018 - 09:01 PM
Silent coat, dynamat or whatever product you choose, they're all the same thing; a bitchumen based material.
The simple rules of sound deadening is to add mass. It is the mass of an object that absorbed the sound wave.
