Fan Belt Alignment
Posted 06 June 2018 - 11:48 AM
20180605_173334.jpg 48.43K 2 downloads
Posted 06 June 2018 - 11:54 AM
looks off but you really need to measure against the other pulleys with a straight rule. I am guessing the alternator needs moving.
Posted 06 June 2018 - 02:07 PM
It does look like the alternator, but how would I move it? It's right on the water pump. File the pump tab down a bit or the the alternator?looks off but you really need to measure against the other pulleys with a straight rule. I am guessing the alternator needs moving.
20180606_150401.jpg 44.53K 0 downloads
Posted 06 June 2018 - 02:09 PM
have you got the lower adjuster fitted correctly. looks slightly cocked out.
Posted 06 June 2018 - 03:04 PM
Posted 06 June 2018 - 04:04 PM
At the moment the tensioner bracket isn't tight at the moment. Waiting for new bolts. See what its like when they arrive. Cheers both
Posted 06 June 2018 - 04:16 PM
sorry but what the hell then i will say yes it is fine for now.
Posted 07 June 2018 - 06:17 PM
Edited by HUBBA.HUBBA, 07 June 2018 - 06:18 PM.
Posted 07 June 2018 - 06:28 PM
The flanges on the water pumps are seldom in the right place and on some water pumps, the bosses on them are out.
I'd be correcting the water pump rather than modifying the Alternator.
