Diff Issues
37 replies to this topic
#1 Pauljb
Pauljb
  • Just Joined
  • 109 posts
Posted 07 June 2018 - 12:24 PM
Hi guys. So a while ago I had a problem with no gearson my 1984 1275 mini. Had a play round with it and posted on the forums. Was told one problem could be the diff pin. Took engine out and removed diff. Begging my ignorance, but this is an x-pin diff right? It looks fine to me an the the only thing i see is the bolt looking thing in the middle is lose. Is this normal? Can't see anything else wrong with it. All teeth look fine and no adverse wearing on anything. Any ideas??
Paul
#2 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 07 June 2018 - 12:29 PM
Standard Diff that. Cross pin has 4 pinions and a machined housing :)
Edited by Midas Mk1, 07 June 2018 - 12:30 PM.
#3 nicklouse
  • 19,063 posts
Posted 07 June 2018 - 12:31 PM
and the pin in the middle will be worn.
#4 mini13
mini13
  • 3,811 posts
thts a standard diff, the x pin or cross pin diff has 2 pins as per the one lined below. Unkless the dif pin has escaped through the casing, or the planet wheels broken up thaeen that looks ok, althoug worth slipping the dif pin out and checking for wear while its out.
I would say more likley, the pinion gear that that meshes with has come off the end of the main shaft, is the engine off the box? of can you get a pic in through the hole the diff was mounted.
unless of course its just a clutch issue
#5 slidehammer
slidehammer
  • 1,208 posts
  • Local Club: LSMOC
Posted 07 June 2018 - 01:11 PM
I hope you have checked the more obvious things before pulling it all apart. Things like the gear linkage / selector. Clutch and clutch release mechanism. If a diff goes they normally either wear and get noisy or go with a bang and do a lot of internal damage.  .
#6 Spider
  • 15,865 posts
Posted 07 June 2018 - 06:08 PM
Is the issue that you have no drive what so ever or that you are unable to get the car in to any gear?
#7 Pauljb
Pauljb
  • Just Joined
  • 109 posts
Posted 07 June 2018 - 07:18 PM
I can select all gears, but no drive, just a horrible noise, like a bike chain coming off.
Clutch pedal had a low biting point, but bled ok and no grinding while selecting gears.
All gears look fine, no wear our missing teeth.
I did notice that I could change gears without using the clutch.
That bolt thing in the middle of the pin does move a bit though.
Box is still on engine. The gear that the diff comes in contact with is fine as well. I'll upload a pic of what I can see.
#8 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 08 June 2018 - 12:41 PM
From what you described I’d be look at the clutch assembly. Particularly the friction plate. As the engines out it’s fairly easy to do.
#9 Spider
  • 15,865 posts
Posted 08 June 2018 - 06:52 PM
I was about to suggest the same. I suspect the friction material has broken away.
#10 Pauljb
Pauljb
  • Just Joined
  • 109 posts
Posted 08 June 2018 - 08:53 PM
Ok. Will check this on my next day off. The chap i bought the car off did tell me that it was fitted with a performance clutch. I'll soon find out when I treasure the cover off and it all falls apart in my hand! Itching to get back in her and drive! Thanks guys.
Will keep you posted
#11 Pauljb
Pauljb
  • Just Joined
  • 109 posts
Posted 12 June 2018 - 09:17 PM
Guys I'm struggling getting the clutch assembly off. I've managed to line evetything up and followed the haynes manual. But it's as tight as nuns chuff! Does the bolt in the middle need to come out (I've tried with bolt in AND bolt out). Even bent my puller centre bolt with the force exerted on it! Is there anything I'm missing???
#12 Its a min
Its a min
  • 284 posts
Posted 12 June 2018 - 09:36 PM
Are you talking flywheel bolt? If so, this needs to come out as does the flywheel keyway under it:
item 12 on the attached.
https://www.minispar...h.aspx?2~13~120
#13 Pauljb
Pauljb
  • Just Joined
  • 109 posts
Posted 13 June 2018 - 06:30 AM
Yeah, that bolt. Took it out and removed the keyway (which only fits in ones way). Fitted the puller with the bolts and tightened the plunger bolt stopped when I saw it bend. Gave it a little persuasion win a hammer but no budge.
#14 Rorf
Rorf
  • 866 posts
Posted 13 June 2018 - 08:12 AM
Something doesn't sound right here; is this a Verto or pre Verto clutch - how about a picture of what you are attempting to do.
#15 Pauljb
Pauljb
  • Just Joined
  • 109 posts
Posted 13 June 2018 - 10:06 AM
Yeah sure. Standard valeo clutch assembly. Verto. The engines a 1275 (from my 1984 mini but not the original engine). This is all I saw when I took the cover plate off.
Was waiting for the 'bang' but never came!
