I did have the flywheel locked in place with a piece of steel bar. I thunk I see where I've gone wrong. The haynes manual also says slot drive should be horizontal. In a rush to very it off I skipped this bit. Oops.
Thank guys. Will let u know what the clutch looks like once off.
Are you saying you didn't lock the flywheel with the slot in a horizontal position? If so, as Nicklouse has said, the C washer may have slipped and is stopping the flywheel/clutch assembly from coming off. And as Dusky has just mentioned, the flywheel bolt and washer/keyway need to be removed. If not, you're trying to pull the assembly whilst pushing the washer against the assembly.
Edited by Its a min, 20 June 2018 - 10:11 PM.
