My mini is fitted with an mg metro engine. It still has the standard needle, bdl. I was wondering if it should be changed. Car has a k and n element inside the drilled airbox, maniflow manifold with stainless exhaust. I have a bdk at home. When the car went for Mot the guy said it was running weak, on the emissions test. I tweaked the mixture screw but now the jet sits very low in the carb throat.
What Needle
germini30
, Jun 08 2018 10:54 AM
6 replies to this topic
Posted 08 June 2018 - 10:54 AM
Posted 08 June 2018 - 11:05 AM
bdk should be fine IIRC
Posted 08 June 2018 - 11:10 AM
bdk will be to rich was in mine and was further modded. try bdp for your set up
Posted 08 June 2018 - 04:27 PM
The correct needle for your car will be the one determined from rolling road testing and tuning. Anything else is a guess.
Ac
Ac
Posted 08 June 2018 - 09:57 PM
True AC but no rr around here for miles
Posted 09 June 2018 - 09:03 AM
I helped a colleague trailer a car 120miles for your new last weekend. You have to be in it to win it!
Ac
Ac
Posted 09 June 2018 - 08:09 PM
when I had same set up as you bdp was put in and run up at slarky and wad good. so good starting point
