Oil Light At Tick-Over When Stinking Hot
11 replies to this topic
#1 Cater_Racer
Cater_Racer
  • 419 posts
  • Local Club: HRCR
Posted 09 June 2018 - 02:01 PM
Hi, my 1293cc is going great, but when it's really hot I get the oil warning light flickering and the guage telling me about 15psi.
Is it rebuild time? or just new Millers CTV 20/50 and crossed fingers?
#2 Bat
Bat
  • 895 posts
Posted 09 June 2018 - 02:54 PM
Hi,
Nothing to loose with an oil change. Check the pressure relief valve while you're there.
Get an oil temperature guage fitted to monitor temps?
Cheers  :proud:
#3 carbon
carbon
  • 2,556 posts
Posted 09 June 2018 - 03:39 PM
What oil pressure are you getting at 2,000 and 3,000 rpm when engine is really hot?
#4 Cater_Racer
Cater_Racer
  • 419 posts
  • Local Club: HRCR
Posted 09 June 2018 - 04:58 PM
50 psi
#5 1984mini25
1984mini25
  • 8,639 posts
Posted 09 June 2018 - 05:02 PM
50 psi
Well the pumps working, but the low idle oil pressure only really means one thing, bottom end rebuild time....
#6 GraemeC
GraemeC
  • 5,224 posts
Posted 10 June 2018 - 07:25 AM
I’ve found Millers CTV did this in my rally car when I’ve done a long special test that has primarily been in 1st gear - ie prolonged high revs with little speed to get air through the cooler. Went away as soon as a high speed, low rev run was done.
I’ve put it down to temp instability of the oil when pushed hard and I don’t use it anymore.
#7 Cater_Racer
Cater_Racer
  • 419 posts
  • Local Club: HRCR
Posted 10 June 2018 - 08:53 AM
Hi Graeme that's excatly the circumstances I have been experiancing, it was on a longish special stage all in first and second gear.
What alternative oils are there?
#8 GraemeC
GraemeC
  • 5,224 posts
Posted 10 June 2018 - 10:21 AM
Vavloline VR1 seems popular, but I've not tried it.
I'll probably get hung out to dry, but I use good old Castrol R - none of the modern additives but it worked back in the day and, for me, it still does now.
It still suffers a little bit of thinning with high temps, but nowhere near as bad.  But you have to use it from a fresh build - you can't just swap over.
#9 MIGLIACARS
MIGLIACARS
  • 2,040 posts
Posted 12 June 2018 - 06:46 PM
I used to use the vr1 it was better than most and cheap enough. I did change it after every event a must in a competition car.
Used to use the castrol r  seemed good to but not easy to lay your hands on in an emergency at an event!!
#10 Cooperman
  • Mini Docs
  • 21,321 posts
Posted 12 June 2018 - 06:52 PM
I do like the Valvoline VR1 and it works well in rxtreme competition conditions.
#11 Cater_Racer
Cater_Racer
  • 419 posts
  • Local Club: HRCR
Posted 13 June 2018 - 03:09 PM
Thanks Peter, I've just changed the oil and filter, draining the oil cooler as well, and refilled with VR1 seems back to normal.
I suspect some castrol 20/50 had found its way in during a top-up.
Gerry
#12 Cooperman
  • Mini Docs
  • 21,321 posts
Posted 13 June 2018 - 06:25 PM
The very best oil I have ever used was Kendall 20w50, but it is hard to find these days. It is blended from Pennsylvania crude oil which is the best.
VR1 is good though and easy to find on the shelf.
Mini Spares
