Overheating Woes
3 replies to this topic
#1 Minigman
Minigman
  • 779 posts
Posted 09 June 2018 - 07:20 PM
So I’ve just installed my newly built 1132cc engine. It’s had a new water pump and stat. The Coventry flat top rad was recored with a 3 core uprated bore.
The engine has done about 250 miles and is fine on the flat. As soon as you get to hill and I mean a big Exmoor style 1:5 3 miler I boil over by the time I get to the top.
Any ideas please?
Edited by Minigman, 09 June 2018 - 07:23 PM.
#2 Minigman
Minigman
  • 779 posts
Posted 09 June 2018 - 07:22 PM
Thought I should add that I did an oil change today and over filled the engine by about 1/4 litre. Not sure if this would cause overheating though. Oil pressure sits at 70 at normal revs on the flat at normal temp (190F).
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 09 June 2018 - 08:38 PM
airlock - timing - head gasket gone -hole engine set up wrong and another 100 and 1 things ig go for timing ....
#4 Minigman
Minigman
  • 779 posts
Posted 09 June 2018 - 09:11 PM
Should be fine. Set up by a very well renowned race engine builder only 200 miles ago. Mind you I just found an 88 degree stat in it. Swapped out for a 74. Beaulieu here we come. Only a 300 mile return journey do that should shake down any other issues.
