Mpi Exhaust Inlet Manifold Rebuild
2 replies to this topic
#1 savo1969
savo1969
    Starting My Mini Up
  • 2 posts
Posted 10 June 2018 - 08:29 AM
i wondered if anyone good help on an issue i have encountered whilst rebuilding my mpi exhaust inlet manifold.
i stripped the manifold down replacing the idle air control unit and the inlet air temperature as a precaution.
the manifold was as you would expect for a 18 year part in not to good of condition.
this is where the problem arises.
the inlet brake servo vacuum hose was broke off in the manifold.i managed to eventually prise the hose out but the damaged plastic fitting is still in situ.
i looked a cross the world wide web and i think i may have found the damaged part but not quite sure.(LZN100220)
could anyone reassure me if this part is the correct part.
many thxs
#2 Itsaminithing
Itsaminithing
  • 851 posts
  • Local Club: Not One Worth Mentioning
Posted 10 June 2018 - 10:20 AM
Fitted to lots of Rovers, MG Rovers, & Land Rovers.... & Minispares stock it! http://www.minispare.../LZN100220.aspx
 -so it looks like you've nailed it.
Wish i knew that part number years ago when i had to drill/tap the manifold & have a brass insert made up to accept a non-MG Rover hose connector.
#3 savo1969
savo1969
    Starting My Mini Up
  • 2 posts
Posted 12 June 2018 - 05:03 PM
thxs for you help.
just ordered one from your link
