Diff
6 replies to this topic
#1 minidave04
minidave04
  • 148 posts
  • Local Club: ashford mini owners club
Posted 11 June 2018 - 07:15 AM
I’m running a promotive kit which uses the standard mini bottom case for the diff but I’m looking to make the drive shafts equal length there’s a kit on mini sport but does not work with the later pot type can I convert to the hardy splice early type and keep it quaife lsd
#2 nicklouse
  • 19,066 posts
Posted 11 June 2018 - 07:46 AM
no idea. but why do you want to add weight for no gain?
#3 minidave04
minidave04
  • 148 posts
Posted 11 June 2018 - 04:07 PM
It won’t be much weight gained but will make the drive shafts equal length which would help with the torque steer
#4 Spider
  • 15,873 posts
Posted 11 June 2018 - 06:32 PM
There's a few different views on this and frankly, in a Mini, I'm of the view that drive shaft lengths don't come in to play here.
#5 Tupers
Tupers
  • 4,176 posts
Posted 12 June 2018 - 01:03 AM
These adaptors emulate the inside of pot joint and provide the mounting flange for a hardy spicer UJ. They should be what you’re looking for.
http://www.med-engin...spicer-adaptors
As far as the torque steer goes have you ever had the car setup by someone that really know Mini suspension? You can bolt on all the fancy parts you want but if they’re not setup properly they’re worth nought.
#6 minidave04
minidave04
  • 148 posts
Posted 12 June 2018 - 07:05 AM
Many thanks these look spot on I have had the car looked at but I thought I’ll make the drive shafts equal length that’s got to help for start and then get another setup properly
#7 nicklouse
  • 19,066 posts
Posted 13 June 2018 - 01:08 AM
will do nothing for torque steer. never had any issues. you are trying to fix something you will not have.
never had torque steer in this when on 6X10s or 9x13s  would happily spin the wheels in first-second and some times third. and went in a straight line. you do not need equal length drive shafts. the length aint the issue.
