Twin Hs4 Carbs With Hif Dashpots?
3 replies to this topic
#1 MK1russ
MK1russ
  • 37 posts
Posted 11 June 2018 - 02:27 PM
I've got a set of twin HS4 carbs that i'm in the process of rebuilding and was wondering if it would be worth fitting the HIF ball-bearing type dashpots/pistons and the LZX2085 quick lift dampers, as i already have them going spare?
I've read on a previous thread on here that it's a worthwhile mod on the single HS type carbs, so assume that it would be on the twin carb setups?
#2 nicklouse
  • 10,076 posts
Posted 11 June 2018 - 02:32 PM
the later HS4 had them anyway IIRC
#3 Pigeonto
Pigeonto
  • 852 posts
  • Local Club: Colchester Mini Club
Posted 11 June 2018 - 06:23 PM
I have the reverse, HS on HIF bodies.
There's a good reason and it's the springs
The HIFs don't have a good choice of spring weights available whereas the HS do.
From dyno testing I've not found one HIF chamber and spring combo which allowed the piston to reach the top and from the fact you're running twins I assume performance is important so keep that in mind if you try it.
'Quick Lift' ? do you mean fast drop ? The oil type ,and spring slightly, dictate the lift speed.
#4 MK1russ
MK1russ
  • 37 posts
Posted 12 June 2018 - 08:54 PM
Yes 'fast drop' was what i meant.
I'll hang on to both sets of dashpot/piston assemblies then and see which ones perform best.
Mini Spares
