Jap Spec Mpi Rad And Cooling.
Best Answer Aria Aradhea , 14 June 2018 - 01:40 PM
Being a side-mounted rad car, you can get any aluminium rad available at known Mini spares shops. Probably better to have one with the electric fan switch sensor on the bottom just like the OEM rad setup.
Go to the full post#1
Posted 11 June 2018 - 07:01 PM
Posted 12 June 2018 - 03:29 AM
I think a 98 JDM is a SPI like mine, not a mpi, make sure you get the right parts before ordering.My 98 jdm mpi has developed a cooling problem, I'm out of the UK at the moment however I am going to buy the full cooling system to fit when I get home in August. The reason for this is that I'm not waiting for parts. I'll buy everything then repair what's needed. Left overs are spares. The question is what is the closest aluminium radiator to the jap mpi spec? I'd love to swap it out whilst I'm on with it.
Posted 12 June 2018 - 11:17 AM
Posted 12 June 2018 - 11:21 AM
so I has no dizzy and a side rad?
jap spec MPi then.
Posted 12 June 2018 - 01:19 PM
IMG_20180612_210420a.jpg 292.99K 5 downloads
IMG_20170603_204500b.jpg 327.75K 5 downloads
Just for your reference, my jdm car's
mpi parts
engine block
coil
oil filter
alternator
all other parts are spi(including throttle body), except the AC relay near the air filter box driver side, this part is unique.
Posted 13 June 2018 - 11:46 PM
Oh my, that is a lot stuffed under that bonnet!!
Posted 14 June 2018 - 01:40 PM Best Answer
Posted 14 June 2018 - 02:37 PM
Hi,
That's Jap spec SPI.
They have coil packs but with the SPI throttle body as you can see in the picture...
Posted 16 June 2018 - 04:14 PM
Posted 16 June 2018 - 04:16 PM
Posted 16 June 2018 - 04:18 PM
