Weird Starting/ignition Timing/distributor Fault
engine electrical
6 replies to this topic
#1 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
  • Local Club: Snowdon minis
Posted 12 June 2018 - 09:29 AM
Hi everyone! Me again....
This is not urgent but still very annoying. I have an old spi 1275 engine which has just been re built with carbs and a 286 cam. The basic question is do you need a special distributor with this camshaft?
I ask because when the car is cold, it will not start. In order to start it you have to retard the ignition timing by somewhere between 50-80 degrees. Then, in order to get the car to drive you have to advance the timing again.
The idle is lumpy at this point but pulls very well.
Once the engine is hot it will start in with the distributor in the advanced position.
The distributor is a brand new ACCUspark. I have checked the ignition advance by sucking on the end of the hose and it works. The vacuum line has no splits, but when the car is running there seems to be no advance.
The only thing I can think of is the distributor is wrong for the application.
Cheers for the help in advance!
#2 nicklouse
  • 17,935 posts
Posted 12 June 2018 - 10:15 AM
you don't need anything special  you may need to have the total advance changed but not much else.
ran a 286 with the old points dizzy for years. it had some small adjustments when set up on the rollers.
you either have build or dizzy issues.
#3 Dusky
Dusky
  • 5,322 posts
Posted 12 June 2018 - 10:53 AM
50-80 degrees retarded? Are you sure Its using a carb dizzy and not the weightless spi dizzy? Checked with a timing light?
#4 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 12 June 2018 - 12:24 PM
OP states it has vacuum advance
Which I'd guess is causing the issues?
Edited by cal844, 12 June 2018 - 12:24 PM.
#5 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
Posted 12 June 2018 - 01:12 PM
Yeah its deffo not the spi dizzy because the spi one only had HT leads, no other wiring for points ect.
I Honestly got no idea what is causing it. Might see if I can borrow another dizzy because the car runs really well otherwise.
#6 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 12 June 2018 - 09:16 PM
Sounds like the valve timing is not set up correctly.
#7 Dusky
Dusky
  • 5,322 posts
Posted 13 June 2018 - 05:11 PM
How did you 'measure' the 50-80° retarded ignition?
I've had a few high compression engines where 4-5° more advance made it impossible to start.
Sounds a bit like you're measuring advance on the wrong lead.
Also tagged with one or more of these keywords: engine, electrical
