Is it possible to change the output shafts in a remote gearbox to pot joints? I have a good rod change gearbox but have the earlier remote change floor in my mini.
Pot Joint Output Shafts
Posted 12 June 2018 - 07:50 PM
Posted 12 June 2018 - 08:01 PM
anything can be done, why not just fit the rod box?
Posted 12 June 2018 - 08:02 PM
Posted 13 June 2018 - 07:55 AM
Posted 13 June 2018 - 08:17 AM
Personally I'd swap the output shafts you want to use into the remote box.
The remote box also has the advantage of securely mounting the engine, no additional lower engine steadies required that constantly break.
Posted 13 June 2018 - 08:18 AM
As the other guys have said, it is possible to swap the diff outputs to what ever you need.
However, you can fit the rod shift box in to your car with the earlier floor. All Aust made minis from start to finish in 1978 had what is essentially a MKI floor pan and this included when we went over to the rod shift boxes in 1973.
The shifter did use a different bracket to those fitted in UK builds, there's nothing to it.
Posted 15 June 2018 - 12:47 AM
Moke Spider, the bracket that comes with the rod change shifter housing will fit uner the Mini K floor without any issues then?
Posted 15 June 2018 - 12:56 AM
i guess it does not look like No6 as that is the UK Mini version. the UK Metro one is different. MokeS did put up a link to the Aus one and it is different to both.
http://www.minispare...m.aspx?2~14~128
Posted 15 June 2018 - 04:56 AM
With an Aussie Rod Shift Bracket - yes. These are different to those fitted in the UK cars.
Posted 30 June 2018 - 08:15 AM
