Lighter Valve Train
#16
Posted 13 June 2018 - 08:48 PM
Have a look at www.facebook.com/ozoap
#17
Posted 13 June 2018 - 09:24 PM
Sounds good.
#18
Posted 14 June 2018 - 03:09 PM
Conical valve springs are the future. I have been running them on Minis for over a year now, High seat poundage, low poundage at full lift, steel top caps weighing 5g.
I hate Facebook. I couldn't find the the conical springs at the link. A search on "spring" yielded nothing. Who supplies them? Thanks.
#19
Posted 14 June 2018 - 03:32 PM
Ian does. PM him.
#20
Posted 14 June 2018 - 08:37 PM
[/UR
L][URL=http://s3.photobucket.com/user/OzOAP/media/Screenshot_20170924-095601_zpsssovjemq.png.html]
Edited by OzOAP, 14 June 2018 - 08:40 PM.
#21
Posted 14 June 2018 - 09:01 PM
#22
Posted 15 June 2018 - 12:06 AM
They're self-damping because of the oval wire cross-section shape and changing radius (so inners are completely superfluous, except for breakage backup). You get higher lift without bind, and because the radius is smaller at the top, you end up with much lighter retainers,
#23
Posted 15 June 2018 - 09:33 AM
They sound good! What sort of rev range would they be an advantage for? I will probably not go much over 7000 rpm.
Edited by grizzler73, 15 June 2018 - 09:33 AM.
#24
Posted 15 June 2018 - 01:24 PM
It all depends on the particulars of the design. I didn't know anyone made them for Minis, that's why I asked about supply. They may not be an advantage at extreme levels of lift and RPM, but that's not typical with Minis anyway.
#25
Posted 15 June 2018 - 01:27 PM
Well Oz has been fitting them for at least 2 years that I know of.
#26
Posted 15 June 2018 - 04:12 PM
On the 998 Mini 7 we rev to 9500.
At installed height they give a seat poundage of 75lb, same as most aftermarket springs, but at full lift(for Mini 7) they are 130lb where as other springs are 180. Less pushrod flex = more lift and controlled timing.
Some race series think they offer such an advantage, they have tried to ban them!
Edited by OzOAP, 15 June 2018 - 05:23 PM.
#27
Posted 15 June 2018 - 05:39 PM
#28
Posted 15 June 2018 - 06:30 PM
#29
Posted 18 June 2018 - 01:03 PM
Interest from Australia and Canada, two countries that have strong links to V8s where the conical spring development came from. They obviously know the benefits.
#30
Posted 18 June 2018 - 02:30 PM
I would change the 1.5 rockers to either the standard ones or get the 1.3:1 rockers, imo 1.5 are overkill with a 296 cam, what does it Idle at and when does power come in?
in my engine, wide open throttle can be used from about 3200 rpm. idle isn't great. when hot it idles at about 12-1500rpm. it wont idle much lower than that.
