Chamber Head Re Size
Posted 13 June 2018 - 08:35 PM
Posted 13 June 2018 - 10:27 PM
Posted 13 June 2018 - 11:27 PM
Posted 14 June 2018 - 06:40 AM
You appear to take more out of the area below the spark plug and put a larger radius on the top part between the valves than the Vizardised diagram, is that correct or just a trick of the light in the photo?
Simon
Posted 16 June 2018 - 04:05 PM
http://imgur.com/gallery/0odTe9W
Posted 16 June 2018 - 08:47 PM
Looks somewhere near. Make up some blanks to protect the valve seats while you're working in there by taking the face off some old valves in the lathe.
The one I did in the picture above was for a turbo motor, so there was a little more taken out to give a larger volume.
Phil.
Posted 16 June 2018 - 08:59 PM
Had a go at the chamber today, not fully polished yet but general shape is there. Am I in the general ball park?
You using a tungsten carbide cutter? Also you got a diagram full size of your porting? I was just going to follow daivd vizards and just a spare head gasket mark it and just draw roughtly to where it needs to be
Posted 16 June 2018 - 11:53 PM
