Spi Throttle Potentiometer
16 replies to this topic
#1 Pogue13
Pogue13
  • 21 posts
Posted 13 June 2018 - 09:29 PM
Hi Guys,
Is there an alternative for the SPI throttle position JZX2962/MMJ10003?
Many Thanks.
#2 FlyingScot
FlyingScot
  • 2,660 posts
Posted 14 June 2018 - 02:17 AM
Not that I’m aware of......
There are similar ones but the direction of travel and the sprung side is different
FS
#3 hungdynasty
hungdynasty
  • 161 posts
Posted 14 June 2018 - 02:23 AM
Technically is it possible to `fix` it, like get another similar size model, switch the internal parts?
#4 MiniAida
MiniAida
  • 75 posts
  • Local Club: None
Posted 18 June 2018 - 10:31 AM
I'm sure it was a fairly standard Rover part, as the one I had on a K-series Freelander looked identical.
As FS said, the direction of travel may be different on some, but I'd personally look for one from any MEMS controlled engine (e.g. early k-series), as the resistance range ought to be the same.
MA
#5 MiniAida
MiniAida
  • 75 posts
  • Local Club: None
Posted 18 June 2018 - 10:39 AM
by the way the early K series engines had plastic throttle bodies where the butterfly frequently became distorted, so most repairers just threw the old one out.
The new one came with a TPS already fitted, so it may be worthwhile looking for the whole plastic throttle body on ebay & asking the seller to check the serial number on the TPS. It just unscrews.
I think I kept one, so will try to check......
#6 MiniAida
MiniAida
  • 75 posts
  • Local Club: None
Posted 27 July 2018 - 08:28 AM
Sorry Pogue 13
I found an old K - Series potentiometer & its number is different JZX345(or 9)1
Maybe MEMS was more versatile than I thought.
Good luck in the search
MA
#7 minimat
minimat
  • 689 posts
  • Local Club: anglian mini club
Posted 27 July 2018 - 11:02 AM
Standard rover part, got a box full of these from various rovers when you could still walk round breakers yards. Just make sure the part number matchs up .
#8 genpop
genpop
  • 474 posts
Posted 31 July 2018 - 10:49 AM
Terrible expensive but you can get it
#9 brivinci
brivinci
  • 1,103 posts
Posted 31 July 2018 - 07:52 PM
The one in the picture doesn't look correct...unless its just for "illustration purposes only" on that site.
#10 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 31 July 2018 - 09:03 PM
Yeh, the one pictured above is for the MPi or other Rover Variants. The SPi TPS is for the SPi TPS. It has a lever arm on the rear and it's spring loaded too. I havent't seen one used anywhere else.
#11 genpop
genpop
  • 474 posts
Posted 01 August 2018 - 08:25 AM
sprocket and brivinci, you are right, this poti seems to fit to MPI only, but I found a dealer in netherlands who has the right ones.
#12 brivinci
brivinci
  • 1,103 posts
Posted 07 August 2018 - 08:55 PM
Might be worth picking up and keeping as a spare seeing as these are getting harder to find.
#13 hungdynasty
hungdynasty
  • 161 posts
Posted 08 August 2018 - 11:21 AM
https://page.auction...tion/w246120065
This is from Japan, please google it in english to read. Not a direct potentiometer replace, instead they supply an adapter with another model of potentiometer, for your reference.
#14 brivinci
brivinci
  • 1,103 posts
Posted 08 August 2018 - 02:29 PM
Very interesting!
#15 Pogue13
Pogue13
  • 21 posts
Posted 11 October 2018 - 08:30 PM
Hi,
Do you have any JZX 2962's?
