Sudden Water Loss And Big Overheat - Likelihood Of Damage?
8 replies to this topic
#1 Jfcrouch72
Jfcrouch72
  • 34 posts
Posted 14 June 2018 - 12:45 PM
Afternoon everyone,
Just interested in getting peoples thoughts.....
so, I was merrily driving along the motorway in my mk1...not pegging it.  All the gauges were happy and pointing in the right direction.  Before I knew it, the water temp gauge was rapidly going up...and I noticed drops of water escaping out the side of the bonnet.  Sod's law dictated that this had to happen when there was no hard shoulder, so I had to limp along for approx 1 mile until i could safely pull over.
Once pulled over, the gauge had gone nice and ballistic and up to 110-115.  Anyway...obviously I had switched the engine off and let the thing cool down.  Whilst waiting for cool down, I noticed the cause of the problem and it was the rubber hose had come off the end of the copper bypass hose that is in front of the rocker cover.  Took about 30 seconds to rectify that.
Once I had refilled with magic sauce a.k.a coolant, I fired the car up and drove home...no issues whatsoever and temp was perfect.
However, although all 'seems' well and it drives fine...I'm more concerned about what I can't see/tell.  So far I can't see any leakages, oil is still the right colour (no water seems to have mixed itself in)
Any thoughts on whether something nasty might have happened during those few minutes?
Thnx.
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 14 June 2018 - 12:48 PM
Personally just run it and see what happens
If you want to do a compression test
Edited by cal844, 14 June 2018 - 12:48 PM.
#3 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 14 June 2018 - 12:51 PM
Should be fine in my opinion. These engines are pretty robust being solid pig iron. You did the right thing by it stopping when you had the opportunity. Just keep an eye on levels and consider a service of your coolant system just to be sure similar won’t happen again
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 14 June 2018 - 01:33 PM
If in doubt change the coolant, new oil and filter and off you go.
#5 unburntfuelinthemorning
  • 2,003 posts
Posted 14 June 2018 - 02:03 PM
Good old cast iron.  It'd be a different story with an aluminium engine.
#6 Jfcrouch72
Jfcrouch72
  • 34 posts
Posted 14 June 2018 - 02:36 PM
thanks guys....i'll definitely keep an eye on it!  I was hoping that it being cast iron would help here.  I'm annoyed at myslef for not checking hoses and clips on a more regular basis...I would have caught it then.
:angry:  :angry:  :angry:  :angry:  :angry:
#7 unburntfuelinthemorning
  • 2,003 posts
Posted 14 June 2018 - 03:50 PM
The motorway with no hard shoulder didn't really help.  Was it a "smart" motorway?
#8 Jfcrouch72
Jfcrouch72
  • 34 posts
Posted 14 June 2018 - 05:49 PM
nothing smart about this motorway :-(  it was blocked off/concrete blocks...they are up to mischief behind there.  Not that anyone was actually there working
#9 Cooperman
  • 23,566 posts
Posted 14 June 2018 - 07:01 PM
I'm sure it will be fine. Been there, done that, with no damage whatsoever.
