Outside of the A-Series evolving differently from its conception, BMC really needed to follow an linear / evolutionary route to replacing its engines as practiced by Renault and Nissan.
Renault - Billancourt > Cléon-Fonte > Energy (possibly D-Type too) > K-Type
Nissan - licensed built BMC A-Series (not sure which models used said engine) > Nissan E engine > Nissan A engine (later renamed 2nd generation E engine upon featuring OHC) > Nissan MA (as well as Nissan CA/etc) > Nissan CG > Nissan CR
BMC did look at an all-alloy A-Series a few times during the 1950s and 1960s in an attempt to reduce the weight from about 120kg-ish (in 1275cc form?), though not sure how the weight savings of the former in all-alloy would have compared to other small all-alloy engines like the 875cc Imp OHC (176lb / 79.8kg) and 598-848cc Reliant OHV* (136lb / 62.6kg-ish - allegedly the latter was a down sized Chinese copy of the 803cc Standard Eight engine and even featured an 8-port head).
For another comparison the unbuilt and arguably unviable 750-998cc 9X engine was said to have weighed 200lb / 90.7kg.
As for the Imp engine, read (in both the Henshaw and Mowat-Brown books on the Imp) the lowest capacity version was originally planned to displace 800cc prior to being uprated to 850-875cc with the max displacement of the original Imp engine being 948cc (the 998cc was apparently not a full production engine while Chrysler cost-cutting meant the 948cc version became 928cc in the Sunbeam). Meanwhile had the Imp been a success (or Rootes avoided most of the problems during its expansion plan around the time of the Imp's development, etc), a taller-block version of the Imp engine was considered displacing around 998-1148cc with the latter displacement used in rally Imps.
*- In Reliant Three-Wheelers: The Complete Story, the non-all-alloy prototype version of the Reliant OHV was said to be 50-60lb / 22.6-27.2kg heavier than the old Austin 7-derived side-valve engine prior to becoming an all-alloy unit. Also there was an unrealised plan to in the 1970s to develop a 60 hp OHC version of the all-alloy Reliant OHV engine (when BRM approached Reliant about building such an engine) originally intended for a four-wheeled Bond Bug known as the Reliant BRM (page 10-13) engine, a project which ended upon Owen Organisation ended its financial support of BRM.
Edited by Mite, 16 July 2019 - 02:18 AM.
