Tuning A 1275 Cc Engine - Part 1
25 replies to this topic
#1 Agus1601
Agus1601
  • 148 posts
  • Local Club: La Tribu Mini
Posted 19 June 2018 - 01:46 PM
HI guys! I am thinking on upgrading my engine and would like to have some advice from you.
Spec at the moment:
- 1275 A+ engine
- +0,30 piston
- Full stg 1 kit (RC40 maniflow + k&n + bits)
- 123 distributor
- bosch grey coil
- champion n9yc sparks
- lucas performance lead set 8mm
- aluminum 3 core radiator
- hs4 carb with some tweaks (needle + spring)
- 3,44 original gearbox
I would like to get aprox 90bhp at the flywheel, so lets do a buy bits list to make that possible
Things I have:
- Lightened flywheel
- hif 44 (not in perfect working condition) a lot of needles, etc
Things I have to buy:
- LETS DO THIS (Thats what jeremy said)
Thanks a lot
Agustin
#2 nicklouse
  • 17,944 posts
Posted 19 June 2018 - 01:52 PM
get a decent head. modify a inlet manifold. change out the KN doe a KN filter that fits in the standard filter box (modified as per Calvers recommendations) service the HIF44, fit EVO001 cam (new followers and suitable springs.
#3 Agus1601
Agus1601
  • 148 posts
Posted 19 June 2018 - 02:46 PM
Hi Nick! Thank always for the answers. The standard air filter box would perfectly suit my hif 44 also? Why not using a k/n cone filter?
How can I do a complete service of my carb? It seems inside to be like very wasted
Any helps? Thank you
#4 nicklouse
  • 17,944 posts
Posted 19 June 2018 - 08:54 PM
carb info
http://sucarb.co.uk/technical/
having the flat surface opposite the carb opening seems to do something with creating standing waves as you get sound reflected of that flat surface. also it is LOUD.
#5 Agus1601
Agus1601
  • 148 posts
Posted 20 June 2018 - 03:03 PM
carb info
Can we do a parts list with everything needed?
So as to buy every bit to make it fully working
Here I leave you some pictures of my hif 44 carb
#6 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 20 June 2018 - 03:27 PM
That carb is pitted(corrosion) but should be serviceable
#7 Agus1601
Agus1601
  • 148 posts
Posted 21 June 2018 - 08:33 PM
where is it possible to get it searviceable? any guys that works with carbs would know how to do it?
Agustin
#8 Turbo Phil
Turbo Phil
  • 2,418 posts
Posted 21 June 2018 - 09:17 PM
Get an SU rebuild kit. The overhaul itself is simple enough.
Phil.
#9 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 21 June 2018 - 09:26 PM
Phil.
This. The hardest part will be drifting out the butterfly spindle bushes, just make sure you note all screw positions, especially the fuel mix screw and idle screws
#10 Agus1601
Agus1601
  • 148 posts
Posted 21 June 2018 - 09:31 PM
If the kit you say is this
http://www.minispare...sic/CRK167.aspx
it does already have that
#11 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 21 June 2018 - 10:05 PM
Perfect, you will need a 1990-1996 front subframe though, so you can run the HIF carb
#12 nicklouse
  • 17,944 posts
Posted 21 June 2018 - 10:18 PM
or just fit the longer top stabiliser bar.
#13 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 21 June 2018 - 10:19 PM
You really don't need to match the subframe to the HIFcarb
If clearance is an issue which I doubt with a 1275, then an adjustable engine steady is all that is needed.
#14 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 21 June 2018 - 10:26 PM
Agustin
The carb is really pitted, have you any photos of where the butterfly plate seats in the main bore ?
Has it been sand blasted ?
#15 Agus1601
Agus1601
  • 148 posts
Posted 21 June 2018 - 10:27 PM
I had it perfectly fitted to my car
