Tuning A 1275 Cc Engine - Part 1
25 replies to this topic
#16 Agus1601
Agus1601
  • 148 posts
  • Local Club: La Tribu Mini
Posted 21 June 2018 - 10:28 PM
That carb is pitted(corrosion) but should be serviceable
where is it possible to get it searviceable? any guys that works with carbs would know how to do it?
Agustin
The carb is really pitted, have you any photos of where the butterfly plate seats in the main bore ?
Has it been sand blasted ?
I dont know what it has been done to it, I bought it as refurbished, with every bit replaced (they told me that)
#17 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 21 June 2018 - 11:41 PM
Can you post photos of where the butterfly seats ?
#18 Agus1601
Agus1601
  • 148 posts
Posted 24 June 2018 - 01:43 PM
can you show me a pic of where you want me to take the photo?
Agustin
#19 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 June 2018 - 03:00 PM
The 1st one with the brass butterfly shut you can see how there is virtually no gap where it seats in the body of the carb
The second one you can just see typical darkening where it does seat, but its smooth.
My concern is that yours may be pitted where the butterfly seats and you may struggle to get a low tickover / idle speed
The gap controls that when the butterfly is shut. When you adjust the idle screw you are opening and closing the gap between the brass butterfly edge and the body.
#20 Agus1601
Agus1601
  • 148 posts
Posted 24 June 2018 - 03:39 PM
Understand you! I think the gap is very little and it closes really well. Also it opens perfect and returns as new. It seems to have been refurbished but the carb itself seems to have had better days
#21 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 24 June 2018 - 05:03 PM
or just fit the longer top stabiliser bar.
I have the long top stabiliser as used on the late cars, an HIF 38 still won't fit, so yes id say to fit the later frame for clearance
Later subframes have the engine mount holes 1/2 inch towards the front of the frame
Edited by cal844, 24 June 2018 - 05:05 PM.
#22 Agus1601
Agus1601
  • 148 posts
Posted 24 June 2018 - 09:51 PM
carb has been already fitted to my car but didnĀ“t run good as my engine is std and didnt have fuel pressure regulator
#23 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 June 2018 - 10:23 PM
Ok so the carb body is ok in the butterfly area.
The only time you need a fuel pressure regulator (FPR) is on a Turbo car.
A standard Mini running an SU or Weber does not need an FPR with either an mechanical pump or electric SU or Facet pumps
Its an un-needed complication.
Did you just try the 44 carb to see how it ran ?
Do you know what needle it has in ?
#24 Agus1601
Agus1601
  • 148 posts
Posted 25 June 2018 - 12:34 AM
Yes I had it fitted with a lot of needles like BBW BDL and BDK as I remember but none of them give me any good result
I know fitted a complete stg 1 kit and it runs much better and fuel consumption is much less
#25 Inno
Inno
  • 138 posts
Posted 08 November 2018 - 05:24 PM
Any progress with the list?
#26 Agus1601
Agus1601
  • 148 posts
Posted 25 November 2018 - 03:22 PM
I have my Mini finally finished with my HS4 carb with some tweeks.
