Standard 998 With K&n. Is A New Needle Required?
minitalia1275
, Jun 20 2018 08:02 AM
5 replies to this topic
Posted 20 June 2018 - 08:02 AM
I have a standard 1990 998. There is a K&N pancake filter fitted with the original aac needle.
Would it make any difference if I fitted an alternative (AAU) or is it not necessary for a filter only change.
Posted 20 June 2018 - 08:31 AM
Yes it will likely need a different needle. AAU may or may not be the needle you require.
Posted 20 June 2018 - 09:33 AM
Hi,
Personally I would not have thought it would make enough difference to need the needle changing if everything else, including inlet and exhaust manifold is still standard.
Always get the fuelling checked to make sure it's correct, anything else is guessing!
Posted 20 June 2018 - 10:48 AM
yes as the air ratio has changed best change it when any thing is changed to get the best out off it, and running right ...what to is the question and that what rolling roads are for ...less you have time money, to learn hoe to roughly do it then ya still needs to r/road it
Posted 20 June 2018 - 04:04 PM
Thanks for the advice. I intend fitting a stage one kit in the future from Minispares that includes an AAU needle.
The car is running ok after I adjusted the carb but there is a flat spot at lower revs. Still, not bad for a standard 998!
Posted 20 June 2018 - 05:07 PM
Personally I'd fit a full stage one or nothing at all, then fit the AAU needle to get you in the ball park
