Hi - I'm after a little bit of advice again please :
I have a 1972 Mini pickup, which I have spent years rebuilding.. and I've just got it on the road.
I changed the engine from the original 998cc A to an early 1990s 1275cc A+ but I kept the original gearbox - which is a magic wand 4 synchro 3.44:1 final drive. I've kept the original 10inch wheels and speedo.
So I bolted the A+ onto the original box using a new 1275 primary gear for A series drop set - keeping the original drop set.
I've put a set of twin HS2 SU carbs on it, with the A+ head, keeping the original cam.
When I drive the Mini, it pulls really well but when it gets to about 45/50 mph, in 4th it "feels" like I need to change up another gear.. I have had it to about 60, but it again "feels" like it revving fast...I say "feels" because I have no tacho in it, so do not actually know the revs..
So, is this normal for a Mini? I can't remember as its been a long time since I drove one, and now I'm used to more modern cars? Or have I messed up the gearing ratio by bolting on the 1275 engine? Is so, what can I do about it?
For ref: Engine code of old engine: 99H387E
and new A+ engine: 12A2EJ02
Thanks for your help.
